disable l2vpn sharing
Description
Disables LSP sharing for Layer 2 VPN pseudo-wires.
Syntax Description
This command has no keywords or arguments.
Default
Disabled.
Usage Guidelines
This command disables LSP sharing for L2VPN PWs. When LSP sharing is disabled, only 1 named LSP is used for a PW. When LSP sharing is enabled, up to 16 named LSPs are used for a PW.
If LSP Sharing is disabled, and more than 1 Transport LSP is programmed into HW, all but 1 Transport LSP is removed from HW, and the configuration is preserved. If LSP Sharing is enabled, and more than 1 Transport LSP was previously configured, the remaining LSPs is programmed into HW as they become available for use.
The following command disables LSP sharing for L2VPN PWs:
This command was first available in ExtremeXOS 15.4.
Platform Availability
This command is available only on the platforms that support as described in the Switch Engine v33.1.1 Licensing Guide document.
